The Create Cable Tray Branch window displays by default when a new pipe element is created.
The Create Cable Tray Branch window allows you to define the name, specification and attributes of the branch under the pipe element.
The Name box is populated with a suggested Branch Name, you can accept the suggested Branch Name or input a new name for the Branch element.
The Wrt position of the new Pipe element within the Model Explorer displays by default.
Click OK to apply the selected specification to the branch or
Cancel to discard any inputs and close the
Default Specifications window. You are returned to the
Create Cable Tray Branch window.
Click OK to save any changes or
Branch Attributes window. You are returned to the
Click OK, the Model Explorer displays the Branch Name and the
Branch at Explicit Position window displays by default, to position the branch, refer to
Branch Head and Branch Tail Position for further information.
Click Cancel to discard any changes and close the
