Cable Design
Pull Pits
: Details
Details
Use to name, assign a specification, modify properties, position WRT to Zone or orientate WRT to Zone.
Name
Enter a name for the pull pit element or the name can be automatically generated using the
Autonaming
icon to the right of the text box.
Spec
Use to select a template or primitive represent a pull pit element to display in the 3D view from the list.
User defined template
Use a user defined template from the catalogue to represent the pullpit element in the 3D view.
if required, modify its properties.
Unset (Use Primitives)
Use a non descript and non editable primitive to represent the pullpit element in the 3D view.
Unset (No Primitvies)
Use an invisible primitive to represent the pullpit element in the 3D view
A
Confirm
window is displayed
‘Do you want to delete all existing primitives’
Position WRT Zone
Format:
Explicitly position the pull pit element at E0, N0, U0 (default)
Offset
Use to position the pull pit element using an offset, default is 0mm.
Lock
Use to lock the coordinates.
Pick New Position
Use to pick a new position in the 3D view for the pull pit element.
Orientation WRT ZONE
X Direction
Use to orientate the pull pit element WRT to the zone.
Y Direction
Related Topics
Pull Pit Branch
Pull Node
