Cable Design
Pull Pits
Pull Pits
Pull pits allow access to the underground networks for both cable pulling and maintenance.
Use to create, position or modify an existing pull pit element, these elements are similar to equipment elements where they can be modelled using primitives and templates.
Pull Node (PULLN) are automatically created with every pull pit, which is then used as connection references for conduits inside the pull pits.
