DRAW User Guide
Output Facilities : Export to DWG or DXF
Click to export the current sheet. When Export is selected, the current export settings are saved.
When Multi Export is selected, the current export settings are saved.
Select Export to DXF/DWG from the drop-down list to define a DXF or a DWG file as the export format.
Select a pre-defined size for the exported file, for example, ISO A3 or ISO A4, or select Auto size paper to define a custom size for the exported output using the Paper ScaleUp field and the extents of the exported data.
The Paper ScaleUp field becomes active if Auto size paper is selected when you specify the desired output size. Refer to Specify paper size for further information.
Click and browse to the required header file.
The functionality is only available if the Use layering by site or Use layering by zone check box is selected.
The Blocking Rules window allows you to create, modify and delete user-defined blocking rules.
Click OK to apply the blocking rules or Cancel to discard any changes and close the Blocking Rules window.
The Layers window allows you to create, modify and delete export layers.
Click OK to apply the layer definitions or Cancel to discard any changes and close the Layers window.
The Layer Rules window allows you to create, modify and delete user-defined layer rules.
Click OK to apply the layer rules or Cancel to discard any changes and close the Layer Rules window.
