DRAW
Add Annotation
Add Annotation
DRAW contains various labelling and annotation facilities.
Dimensions
Autolabels
Label Objects
Weight and Centre of Gravity Label
Label Format Tab
Label and Dimension Blanking
Leader Line Gaps
Add Symbols to Drawings
Add Images to Drawings
Add Overlays to Drawings
Add Text to Drawings
Add Tables to Drawings
Add Marker Points
Add Connection Points
Add Excel Tables
Grid Ruler
Automatic Tagging
Pipe End Labels
Label Position
Modify Labels and Annotations
Clean Up Annotations
Sort Dimensions
Model Reference Check
Fill Objects
When a 2D drafting element, for example, an annotation is added to a Sheet or View that does not own any Sheet Note or View Note elements, a new note is automatically created. The 2D drafting element is automatically placed under the new note.
If the Sheet/View owns a single note, the new element is automatically placed under that note.
If the Sheet/View owns multiple notes, the new element is added either to the currently selected note or if no note is selected, the first note listed in the Draw Explorer.
