With local positioning, Labels are positioned around their significant design elements in such a way as to minimise Label overlap and leader-line crossing. Labels are not moved from their initial positions unless it is necessary. If they are moved then, as far as possible, leader lines are straight and at ± 45° to the VIEW axis.
With remote positioning, labels are positioned around the VIEW border. It is possible to define a margin outside the VIEW frame that defines the positioning of the Labels. It is also possible to define a side of the VIEW frame alongside of which repositioned Labels are
not placed, and the minimum permissible gap between any two Labels can also be specified.
