The Hole Management Utility which creates and manages penetrations is available only in the
Pipework and
HVAC Designer applications, on the
Piping or
HVAC tab, in the
Penetrate group, click
Pipe, select
Penetration Utility from the drop-down list to display the
Managed Hole Utility window.
        In the Clearance text field, enter how much clearance to apply to the penetrating item. The clearance is not applied if the software detects a clash with a pipework or HVAC component that has hole size properties.
        Select the Insulation check box to apply insulation to the penetrating item.
        Click Auto Penetrate CE to automatically create holes in the selected Current Element.
        To create holes individually click Create Hole, you are prompted to pick a panel, pipe or HVAC branch that penetrates the selected panel, section or wall element. The creation of the hole is identical to the automatic hole creation.
        To merge holes, from the Merge Holes part of the
Managed Hole Utility window, click
Pick Holes, you are prompted to pick a Managed Hole fitting to be combined into a single merged hole.
        Click Merge Holes, the software creates a merged hole containing the selected penetrations. To change the shape of the merged hole, refer to
Modify Holes for further information.
        To modify a created hole, from the Modify Holes part of the
Management Hole Utility window, click
Modify CE to display the
Hole Management Definition window, modify the created hole as required, the
Free Hole Boundary Editor can also be started from this window.
        To generate and define a report on selected holes, click Hole Report. The report can then be printed or exported to Excel.
        The Hole Association Filter pane searches for Managed Holes and displays the search results in the Hole Report. The filter criteria specify which Managed Holes is selected:
        In the Report Headings pane select headings using the check boxes that are required on the report from the three categories,
Hole,
Penetrated structural item and
Penetrating items.
        To select all headings click Select All Headings or to remove all headings click
Remove Headings.
        The Managed Hole Report window displays the report generated by the specified selection criteria and report headings.
        Right-click the Hole Associations list to display the following pop-up menu:
