Referring to the Cable Tray Hierarchy, the first task that you should perform using the Cable Tray tab is to create a
Pipe Element in the Design Database.
Before creating a Pipe Element the correct Database elements should already be present in the Model Explorer, for example, a World, Site and Zone should exist. If this is not the case, refer to
Getting Started with Plant for a detailed explanation of creating these standard elements.
