Extend Through allows the user to specify a plane, position and orientation to extend either end of the section to. The section only extends along its
Z axis, that is its extrusion direction, as the plane is infinite in its planar dimensions.
The functionality available from the Extend Wall - Relative window is identical to the
Extend Through window. For more information, refer to
Extend Through
Extend By allows the user to lengthen or shorten the wall by moving its Start or End position through a specified amount. On the
WALLS AND FLOORS tab, in the
Tools group, click
Walls Ends, select
Extend By from the drop-down list to display the
Extend Wall - Explicit window.
When the window is displayed a label is placed at either end of the section to identify the Start and
End locations. The
Extend drop-down menu allows the user to select which end of the section is extended, the choices being
Start,
End or
Pick.
If the Pick option is selected, the user is prompted to select the end of the wall to be re‑positioned then click
Apply.
The user can move the end of a wall either by Distance or by a
Proportion of the wall’s current length, by selecting the appropriate option and entering the desired amount. Entering a positive value lengthens the wall and entering a negative value shortens it.
On the WALLS AND FLOORS tab, in the
Tools group, click
Walls Ends, select
Trim Ends from the drop-down list to, the user is prompted to
‘Identify end to be trimmed’.
Tools group, select
Mitre Ends from the drop-down list. The user is prompted to
‘Pick ends of wall to be mitred’.
The functionality available from the Tidy Joints and
Tidy Nodes window is identical to that described in the Sections application, for more information, refer to
Tidy.
Tools group, click
Walls Ends, select
Trim Connected from the drop-down list to, the user is prompted to
‘Identify element attached ends are to be trimmed to’. For more information, refer to
Trim.
