It may be necessary during the design process to split a straight wall that already exists into shorter lengths where it intersects with another element. On the
WALLS AND FLOORS tab, in the
Tools group, click
Split Wall to display the
Split Walls window.The window must be populated before any elements can be picked in the 3D graphical view.
The only method to select Elements to be split on and
Elements to be split in the 3D graphical view is
Pick using cursor.
From the Connections at split pane of the
Split Walls window, the user can specify how the ends of the new shorter length walls are to be connected at the split points:
By default, the Confirm before splitting checkbox is selected, this means a Confirm window is automatically displayed before each split occurs.
Click Apply, the user is prompted to
‘Identify item to be split on:’. Pick these items in the 3D graphical view which determine the split points. When the items have been picked, press
Esc.
The user is then prompted to ‘Identify wall to be split:’. Pick the walls to be spilt in the 3D graphical view. When these items have been picked, press
Esc.
Click No to discard any inputs and close the window.
Click No to discard any information and close the
Split Walls window.
