By default, the Clearance of the split rail is 0mm and the
Cut Plane check box is selected.
To split the rail using an existing element in the 3D Model, from the Split Rails window, click
Split Rails on Element, the user is prompted to ‘
Pick the element on which to split the rails/kickplates’.
To split the rail between 2 points in the 3D Model, from the Split Rails window, click
Split Rails between 2 points, the user is prompted to ‘
Pick rail or kickplate to split’.
Once the rail/kickplate is picked in the 3D graphical view, the user is prompted to ‘Pick split position (Distance [0]) Snap:’ The selected rail/kickplate is split between the ‘picked’ points.
