Structural Design
Handrails
: Curved Handrails
Curved Handrails
If required, SLH can create curved handrails, the functionality to create a curved handrail is identical to that for the creation of a straight handrail. With the exception curved handrails can only be created with the ‘
Copy Route Path
’ functionality from the
Route Definition
part of the
Create Handrail
window and the user must select a curved GENSEC element.
The user is prompted to ‘
Pick element to copy route path from’
, from the 3D view.
Kick Plates on Curved Handrails
Kick plates on curved segments of a handrail (not corners) follows the curved route path, a segmented kick plater terminates at the end of each curve. A continuous kick plates run the whole length of the handrail.
