On the STAIRS LADDERS HANDRAILS tab, in the
Create group, click
Stair Flight to display the
Create Stair window.
All of the tasks that the user would carry out with the creation of a STRFLT are initiated from a central Create Stair Flight window which acts a task hub. The
‘General Attributes’ window is always the initial window, regardless of the selected SLH element or representation mode, further windows are presented (progressive disclosure) prompting for user input.
By default the Representation Mode is Layout and
General Attributes part of the
Create Stair Flight window is displayed.
From the General Attributes part of the
Create Stair Flight window, select a default standard from the drop-down list of available defaults, if there are no defaults, refer to the SLH Administrator, the default is
Select.
In the Name: field, type the name for the new STRFLT element, or select
Autoname Stair Flight. The default is
Unset.
The Width field specifies the width of the STRFLT element, it is automatically populated with the default of the selected standard (if set up by the SLH administrator). If required the user can amend the width of the STRFLT element within the minimum and maximum defaults.
Click Next, the
Reference Points part of the
Create Stair window is displayed.
The Stair Summary part of the
Create Stair Flight window is populated with the Width dimension of the STRFLT element.
Click Cancel to discard any inputs and close the
Create Stair Flight window.
To create a new STRFLT element, the user must select a start (FROM Reference Point) and end
(TO Reference Point) for the STRFLT element, from the
Create Stair window. By default no reference points are selected.
The direction of the stair flight is determined by the which reference point is selected first.
If the user selects the FROM Reference Point first, from the FROM Reference Point part of the
Reference Points window, select
Pick Edge (FFL). The user is prompted to
‘SLH Flight - Pick FROM Edge’. Once the edge has been selected it is labelled as
FROM Edge in the 3D view.
From the TO Reference Point part of the
Create Stair window, select
Pick Edge (FFL), the user is prompted to
TO Edge in the 3D view.
The Evaluation part of the
Create Stair window is populated with feedback on the reference points. When the selected reference points are acceptable, the following message is displayed:
‘The selected reference points successfully passed an initial check.’
The Stair Summary pane of the
Create Stair window, is populated with the Overall Rise, Going, Width
The modification process of TO and
FROM Reference Points is identical, therefore for the purposes of this user guide, only the
FROM Reference Point position modification is described.
To modify the FROM Reference Point position, from the
Modify Position, the
FROM Position window is displayed.
Modify the position of the FROM Reference Point position as required, click
Apply to modify the position and close the
FROM Position window, or click
Dismiss to discard any changes and close the window.
From the To Reference Point part of the
Pick Elevation, the user is prompted to
‘SLH Stair Flight - Pick Face or Edge’ in the 3D view.
If required the user can alter the direction of the STRFLT element, from the TO Reference Point part of the
Create Stair Flight window, click
Flip Stair Flight Direction.
‘Pick Support Element’. The user is prompted to ‘
SLH Stair Flight - Pick FROM Support Element’.
Once the Stair Configuration part of the
Create Stair Flight window is displayed, it is automatically populated with all the allowable configurations allowed in the defaults.
From the Stair Configuration part of the
Create Stair Flight window, input the offset distance into the
X Offset field then select
X Offset from.
The Positioning Control window is displayed, the functionality allows the user to pick positions in event-driven graphics mode. For more information on the
Positioning Control window, refer to
Positioning Control.
Used for positioning the stair flight along the upper reference edge. Input the nudge increment into the Nudge field (default 100mm), click the arrows to nudge the strair flight along the X axis in the 3D view.
All of the configurations available for selection are displayed in the Stair Configuration part of the C
reate Stair window. By default the configuration closest to the defaults is highlighted.
The user can now add handrails to the stair flight, from the Handrail part of the
Create Stair window, select the from the
Handrail Configuration drop down list of available handrails.
Click Next to display the
Extension and Landings part of the
The Extension and Landings part of the
Create Stair Flight window is populated with data for the new STRFLT element.
Some of the fields in the Create Stair Flight window are populated with the defaults set by the SLH System Administrator and others are populated with results of calculations made by the SLH application using the defaults file.
The Extensions pane of the
Extensions and Landings part of the
Create Stair window is populated with the lower and upper extension lengths (which are within the minimum and maximum default values) for the new STRFLT element.
Only available in Detail, for more information refer to
Detail Mode
Dependent upon the selected configurations, the Landing part of the
Extensions and Landings window can be used to configure, add or remove the intermediate landing to user/company standards and/or requirements.
To add a landing, click to select the Landing check box, the SLH application adds a landing to the stair flight.
Use the dimension label from the Landing Options part of the
Create Stair Flight window, to display the length and/or height of the landing in the 3D view.
In the Rises Above or
Rises Below boxes, select the number of rises above and below the landing. If the user changes the number of rises above the landing the number of rises below the intermediate landing automatically adjusts within the height constraint and vice versa.
Click ‘Pick Tread’, the user is prompted to
‘SLH Stair Flight - Pick an aid line Pick Aid:’.
