Structural Design User Guide
Panel Fittings : Compound Fittings : To create a Sub-Compound Fitting
Make sure the compound fitting is the CE, on the Plates tab, in the Create group, click Fitting, select Sub-Compound Panel Fitting from the list to display the Create Sub Fitting window.
The functionality of the Create Sub Fitting window is identical to the Create Panel Fitting window, For more information, refer to Single Panel Fitting.
