On the PLATES tab, in the
Settings group, click
Default plate specification to display the
Plate Specification (Default) window, by the default the specification is
Unset.
Click OK, the following warning message is displayed:
Click OK to close the
Warning window and navigate to the correct level or lower in the hierarchy and select the database element as the new CE.
The Panel/Floor Tolerances govern the tolerances (clearances) of the panels and floors elements.
From the PANELS tab, in the
Tolerances, the
Panel/Floor Tolerances window. The
Panel/Floor Tolerances window is populated with the default tolerances, if required the user can modify the tolerances to suit as per project/ model requirements.
The Draft Edge Drawing Defaults window is populated with the defaults governed by the default specification. From the
PANELS tab, in the
Tolerances, the
Draft Edge Drawing Defaults window.
