On the SECTIONS tab, in the
Tools group, click
Bracing, select
Bracing Configuration from the drop-down list to display the
Bracing window.
In the Section Data part of the
Bracing window, allows the user to define the profile, specification and attributes for the bracing configuration (replacing the default specification). Select
Profile to display the
Section Specification (Form) window is displayed.
From the Bracing Plane drop-down list select a design aid for the creation of a bracing configuration:
In the Available Bracing Configurations part of the
Bracing window is populated with the supplied standard bracing configurations along with a parameterised graphical representation of the configuration.
Click Apply to create the Bracing Configuration, depending on the selection made in the
Available Bracing Configurations window determines the window displayed to the user.
Click Cancel to discard any inputs and close the
Bracing window.
From the Configuration part of the
A/K Bracing window, select the required configuration, by default
Bracing A is selected.
If required, input the initial gap into the Gap A and
B fields, refer to the 3D representation for reference.
If the Confirm check box is selected, design aids represent the bracing plane and elements are displayed.
The user is prompted to ‘Pick first section’, the 3D representation on the
Bracing window can be used as a guide.
Click Accept to create the bracing configuration.
Click Reject to discard the bracing configuration.
As part of the design process, once bracing configurations have been created the bracing gaps may require adjusting. On the SECTIONS tab, in the
Tools group, click
Bracing, select
Bracing Gaps from the drop-down list to display the
Bracing Gaps window.
The Brace Gaps window is populated with all the available gap types which can be modified, along with the default Gap and a graphical representation of the Brace Gap. Select the required gap type and default gap, click
Apply, the
Brace Gap(s) window is displayed.
From the Brace Gap(s) window, use the 3D representation window as a guide, the default is displayed in the
Gap A field.
By default the Confirm check box is selected, design aids represent the bracing plane and elements are displayed in the 3D view.
The user is prompted to ‘Pick first section end’, use the 3D graphical representation as a guide.
Click Accept to create the bracing gaps.
Click Reject to discard the bracing gaps.
