Allows the user to graphically select one or more sections to be split on from the graphical view. When this option is selected the prompt ‘Pick a selection to split on:’ is displayed. One or more sections may be selected, the selection process is terminated when Esc is pressed.
Allows the user to select points in the graphical display to create one or more aid lines to split on by selecting points in the graphical display. When this option is selected the prompt ‘Line start (Snap) Snap:’ is displayed. One or more lines may be created. Press Esc to terminates the creation process.
None - the section is split at the Justification line of the section it is split on. However, there is no connectivity created between the sections.
Nodes - the section is split at the Justification line of the section it is split on. SNOD and SJOI elements are created which connect the split sections to the section(s) they were spilt on.
Trimmed - the section is split at the Justification line of the section it is split on. SNOD and SJOI elements are created which connect the split sections to the section(s) they were spilt on. The split sections are trimmed to the Pline at the extremity of the section(s) they split on.
