ON the
SECTIONS tab, in the
Tools group, click
Merge, select
Merge the user is prompted to ‘
Pick Panel/Section or end of first gensec to merge:’.
The first section picked is the dominant section. The prompt changes to ‘Pick Section to merge or <esc> to finish:’. The user must then pick the other sections to be merged from the 3D view.
Press Esc to terminate the picking process.
If the Esc is pressed before at least two sections to merge have been picked an error message is displayed.
On the SECTIONS tab, in the
Tools group, click
Merge, select
Fillet from the drop-down list the user is prompted to
‘Pick end of first gensec/section to fillet:’.
Click OK to abandon the filleting operation.
As a GENSEC cannot own fittings, a Confirm window is displayed that states that filleting the sections removes all fittings and asks the user to confirm whether to proceed. Click
Yes to display the input window for the fillet curve radius.
Click No to abandon the filleting operation.
By default the curve radius is 1000, click OK to accept this value. Alternatively enter a value greater than 0 in the text box and then click
OK.
Once the fillet radius has been entered, the Fillet Point and
Start and
End of the GENSEC are displayed with aid graphics on the two sections in the 3D view together with a further confirmation message.
Click Yes to fillet and create the GENSEC
Click No to cancel the creation of the fillet.
