Structural Design
Structural Catalogue
: P-line Identification
Each p-line is identified by a two, three or four letter code (known as its PKEY) which identifies its relative position in the 2D profile
Each p-line is extruded in the design model to represent a line running along the length of a section.
The most commonly referenced PKEYs use the following naming conventions (each profile uses only a subset of these):
BBH
Bottom bolt hole
BBHL
Bottom bolt hole, left
BBHR
Bottom bolt hole, right
BLW
Bottom left of web
BLWT
Bottom left web top
BOC
Bottom of channel
BOS
Bottom of steel
BRW
Bottom right of web
BRWT
Bottom right web, top
FOC
Face of channel
HBA
Hole, bottom of angle
HOA
Hole, outside of angle
IOC
Inside of channel
LBOA
Left bottom of angle
LBOC
Left bottom of channel
LBOS
Left bottom of steel
LBTS
Left bottom top of steel
LTBA
Left top bottom of angle
LTBS
Left top bottom of steel
LTOC
Left top of channel
LTOS
Left top of steel
LTTA
Left top of angle
NA
Neutral axis
NAB
Neutral axis bottom
NAL
Neutral axis left
NALO
Neutral axis left outside
NAR
Neutral axis right
NARO
Neutral axis right outside
NAT
Neutral angle top
RBOA
Right bottom of angle
RBOC
Right bottom of channel
RBOS
Right bottom of steel
RBTS
Right bottom top of steel
ROA
Right of angle
ROC
Right outside of channel
RTBS
Right top bottom of steel
RTOC
Right top of channel
RTOS
Right top of steel
TBH
Top bolt hole
TBHL
Top bolt hole, left
TBHR
Top bolt hole, right
TLW
Top left of web
TLWB
Top left web, bottom
TOAX
Top of angle, X orientation
TOAY
Top of angle, Y orientation
TOC
Top of channel
TRWB
Top right web, bottom
TOS
Top of steel
TRW
Top right of web
