A Geometry Set, which defines the overall physical shape of the item in terms of a set of 2D and/or 3D basic shapes (known as primitives). A sectional profile is made up of 2D primitives only (which are extruded to form a 3D section in the design model); a joint or a fitting is made up of 3D primitives which define its complete volume. A geometry set can include negative 3D primitives to represent holes.
Point Set, which defines a number of reference points and directions superimposed on the geometric shape so that individual parts of that shape can be identified and manipulated. These reference points can include p-points, which represent a 1D point position and a direction, and p-lines (or plines), which represent a 2D line and a direction.
