The representation of a floor element can be modified from its representation defaults. On the WALLS AND FLOORS tab, in the
Settings group, click
Options, select
Floor Representation from the drop-down list to display the
Modify Representation window.
From the Modify Representation window, the user can modify the level and obstruction which affect the way elements are displayed in the 3D view and how they are dealt with when checking for clashes between design elements.
The Panel/Floor Tolerances govern the tolerances (clearances) of the panels and floors elements. On the
Options, select
Floor Tolerances to display the
Panel/Floor Tolerances window. The functionality available to the user is identical to that available from Panel Tolerances, refer to
Panels Tolerances.
All the tasks that a user would carry out that are associated with the default specification are initiated from the Floor/Screed Specification (Default) window. The functionality available to the user is identical to for the other three applications. Refer to
Default Section Specification.
All the tasks that a user would carry out that are associated with the default specification are initiated from the Wall Specification (Default) window. The functionality available to the user is identical to for the other three applications, refer to
Default Section Specification for more information.
The Draft Edge Defaults window is populated with the defaults governed by the default specification. From the
Options group, click
Draft Edge Definition, to display the
Draft Edge Definition window.
The Draft Edge window is populated with the defaults governed by the default specification. From the
Draft Edge, to display the
Draft Edge window.
