Structural Design
SDNF Export/Import
Technical Information
: Issues Concerning Entity Comparison
Some systems do not use unique piece marks. On import, piece mark values are transferred to the :SDNFEMARK UDA field. When SDNF exports them, the AVEVA E3D™ reference number is put into the :SDNFMARK UDA field. Theoretically, if these are unique between and within each system, then SDNF can cross refer the members between packages. However, some packages (XSteel, for example) do not use unique piece marks. This leads to multiple instances of the same piece mark within the imported model. It then becomes impossible to use :SDNFMARK as a unique pointer to the incoming member. Therefore, repeated imports and merging from other packages into AVEVA E3D™ and comparing the differences will give wrong results. In fact, subsequent merging of the models will give drastically wrong results. Using the memberID as an identifier is also not reliable as this value is really dependent upon the sequence of export from the other package. There is no other attribute or flag that can be used to uniquely identify members in this situation. Trying to use member position as an additional discriminator would actually hide differences, and not be any better.
This is an impossible problem to solve. When repeatedly importing into AVEVA E3D™, the best thing is to delete the old structure, or find some way to merge them.
This applies to both linear and plate members.
