Structural Design User Guide
SDNF Export/Import : Technical Information : Using Linear Member Cutbacks
The use of the Use Cutbacks option will be the same for exporting an AVEVA E3D™ model in either SDNF format, i.e. v2.0 or v3.0.
When the Use Cutbacks check box is left unchecked the start and end positions will be the start and end positions of the Justification Pline of the member.
When the Use Cutbacks check box is checked the start and end positions will be the positions of the virtual nodes derived from the nodes to which the start/end is connected. The start and end cutbacks will be set to be the distance between the virtual node position and the Justification Pline position.
Below is the relevant Export dialog with the Use Cutbacks option indicated.
The use of the Use Cutbacks option will be the same for importing a model in either SDNF format, i.e. v2.0 or v3.0.
When the Use Cutbacks check box is left unchecked the start and end positions of the member will be set to the start and end positions. Any cutback values will be ignored.
When the Use Cutbacks check box is checked the Start and End positions of the member will be 'trimmed' in accordance with the start and end cutback values.
