To export a steel structure to a SDNF file, on the Sections,
Plates or
Stairs Ladders Handrails tab, in the
SDNF group, click
Export to display the Export window.
Clicking Target Information displays the
Export Target Information window which contains information about the 3D steel detailing package which the SDNF file is being transferred to.
The current file settings are indicated on this Export Target Information window. Changing the Target Package by using the Target Package selector button on the right-hand side of the window may cause the text to change giving the full path names of the respective files. Do not be concerned that the path name may be truncated by the insertion of the ellipsis (…): it is modified only for display purposes on the window.
The two main options are, Auto and
Manual which are activated by selecting the appropriate radio button.
Auto causes the interface to select automatically the mapping tables for the Target Package indicated by the Target Package selector gadget on the right hand side of the window, according to the system configuration files.
Manual activates other buttons, which are greyed out for the
Auto option. Selecting this option changes the window to be similar to below.
The user can select the file type using the Profiles,
Materials,
Orient'n or
Unicode radio buttons and enter the full path name of the file in the data entry area. The user can also include system environment variables in the path name as long as they are in the proper AVEVA E3D™ format, e.g.%ENVVAR% being the AVEVA E3D™ representation of the ENVVAR environment variable.
Once the user has entered all the correct data on the Export Target Information window, click
OK and the interface variables will be updated. Clicking
CANCEL will close the window, leaving the original interface variables unchanged.
On the Export Information window there is a drop-down list which the user can use to select which SDNF version to output.
Clicking Export Information displays the
Export Information window which contains information about the export process.
The user can either type the full folder path name of the output file, or click Browse to display a File Browser. The interface tests to see if the file exists and if it does, the user will be asked whether to overwrite it. If the file does exist and the user wants to overwrite it, the file mode beside
Browse will change from
WRITE to
OVERWRITE. The output file is rechecked for write/overwrite status during the actual Export process. This is because the user can perform repeat Exports without changing the output file name.
The SDNF file may have several sections: a header, Packet 00; a set of Linear Members,
Packet 10; a set of Plates,
Packet 20 and their holes (Packet 22); a set of Connection Details,
Packet 40, and a set of Arc Members (Packet 60). The header is compulsory: any other Packets are optional.
Selecting the information to be contained in Packet 00 is performed by navigating to, or below, the relevant AVEVA E3D™ Design SITE, ZONE or STRU element which contains the required header information. This is done by using the
Members list window on the main
Export window. When at, or below, the correct element, click
Use CE on this window and the source text will indicate from where the interface will get the information. If there is not enough space on the window the element's reference number is output rather than its name.
At first the entry fields are greyed out but the user can read the contents. To modify the contents of the fields click Edit on the
Export File Header Details window and the fields become active allowing the user to enter any revised data. Click
Apply and the data will be transferred back to the chosen header object, overwriting the original data. Clicking
Cancel will leave all the data unchanged.
Using the toggles on the Export Information window, the user can select whether to export
Packet 10 (Straight), Packet 60 (Curved) or
Packet 20 (Plates) with the option of their holes, Packet 22 (Holes). The user cannot output
Packet 40 (End Connections) without outputting either
Packet 10 (Straight) or Packet 60 (Curved). If the user wants neither
Packet 10 nor Packet 60, the sub-options,
Members only and
Members + End Connections are inactivated and greyed out. Similarly, one cannot output Packet 22 (Holes) without outputting Packet 20 (Plates). But the user will be able to export Plates without their holes.
Once all the correct data has been entered on the Export Information window, click
Clicking Run Information displays the
Export window which allows the user to view the Log File after the export process is complete by clicking the
Log File? check box.
Clicking either the Brief or
Verbose radio buttons the user can choose which format messages are displayed.
The Test Run? option allows the user to suppress the updating of all the Export flags. This is so that the user can see if there will be a successful Export of the model. The user may find that the Profile or Material mapping files are not quite up to date which might cause a failure in the Export process. Therefore, the user can select this option to define this as a test run.
After the Export process has completed, Test Run? is reset to false. This is so that the user is forced to state categorically each time the model is Exported that the run is a trial.
Once all the correct data has been entered on the Run Information window, click
Add CE just adds the current element to the list. This also implies all items below the current element in the database hierarchy. The WORL can not be added to the list.
The Add by Pick option allows the user to select an item from the
3D Volume View. It is similar to other Design pick functions. Selecting this option brings up a
Status window and puts the user into a mode where an item from the
3D Volume View can be picked. The user can also pick a sequence of items in succession to add to the Export list. Click the
Esc key when complete. If the user does not want to continue, click the
Esc key.
Add Structure will attempt to climb to the Structure owning the current element and add that to the Export list. A warning will be displayed if there isn't an owning Structure.
There is also a set of methods by which the user can remove items from the Export list. These options work only on entries in the Export list, rather than in the model. As with adding to the Export list, removing from the Export list will cause the item or items removed to be returned to the default colour as defined by this interface.
Remove CE looks for the name of the current element in the list and removes it if present.
Remove by Pick allows the user to select something from the 3D Volume View and, if it is present in the Export list, the name will be removed. As with the
Add by Pick option, the user may select a series of items to attempt to remove from the Export list until the
Esc key is clicked.
Remove Selected is a means by which the item selected in the Export list is subsequently removed. Select the item first in the list, then click
Remove Selected.
Clear just removes everything from the list.
Cancel closes the
AVEVA SDNF Export window.
Export executes the Export process. As it proceeds the user is kept informed of the progress by means of messages at the bottom of the main Design window as well as by forms and prompts.
The Control drop-down menu has two options;
Re-initialise and
Exit. Changing any mapping files or any other variables,
Re-initialise will reload these files to save the user having to rebuild the whole user interface from scratch. The
Exit command will remove all forms and menus and global variables associated with the interface.
The General drop-down menu has one option,
Highlight which displays the
Highlighter window enabling the user to identify new, changed and deleted items in the model. This has more relevance to the Import process and is described in more detail in
Highlighting Changes in the Design.
Click YES and the interface will wait for another period of time. Clicking
NO will cause the interface to stop where it is. Finally the system will indicate its completion, whether successful or not. This completion message should be read in conjunction with the log file, if any errors are indicated.
To inspect the log file later, save it with the File > Save as option in the
SDNF File Viewer window which will bring up a File Browser, or by clicking
Save as to the suggested filename. Either way, if the file already exists, the user will be asked whether to overwrite it. The log file window may then be closed by clicking
Cancel.
If the Brief mode has been chosen on the
Run Information window for displaying the log file, the window displaying the log file will filter out all Warning messages, leaving only the Error messages. Saving the log file, however, all messages will be retained in the file.
Panels in AVEVA E3D™ are to be transferred as Plates using Packet 20. This will cover
stiffeners, floor and toe plates. Bent plates will also be transferred if they are expressed as their component flat plates. If Bent Plates are to be treated as Angle linear members then they should be modelled as such.
If the AVEVA E3D™ Design Penetration Application is used to generate Catalogue holes, the resultant holes, kicker plates and stiffeners will not be exported because they are contained in a Catalogue definition. Some holes and negative primitives can be transferred from the design. See next section.
The following test can be performed after installing the AVEVA SDNF product to make sure that the installation is complete and correct. All the required testing material can be found below the sub-folder
SDNF\test\results\export in the user data folder.
Change the view in that window by selecting the 3D VIEW tab, in the
Manipulate group, select Isometric and select
Iso 3 from the list.
Click Target information on the
AVEVA SDNF - Export window to display the
Select the Auto mode toggle option and select "AVEVA" from the list of Target Packages on the Target Package selector gadget on the right hand side of the window. This causes the system to automatically detect the Target Package's Profile mapping table and Material mapping table.
Click Export information on the
Export Information window.
Check that the SDNF file header (Packet 00) is coming from /SDNF-CONFIG-DEMO-SYSTEM. Use the navigator and browser if necessary.
Select which SDNF Packets to export: Packet 10 (Straight), Members + End Connections and
Packet 20 (Plates). Select SDNF version 3.0.
Click Run information on the
Run Information window.
Select the Log File? option and choose
Verbose for the message mode.
Do not select the Test Run? option as this is not a test run.
To add the SITE to be exported to SDNF, Select SITE /TEST-SDNF-INTERFACE in the form's Members list. Click
Add CE. This will cause all the members in the
3D Volume View window change colour to indicate they are being exported.
The AVEVA SDNF - Export window look similar to this.
On the AVEVA SDNF - Export window, click
Export.
When the process is complete, the user will be asked whether to inspect the log file. The user can then save it with the File > Save as option on the SDNF
File Viewer window to bring up a File Browser, or by clicking
Save as to the suggested filename. The log file window can then be closed by clicking
Cancel.
