Click Select to choose between CE or a picked curved section.
The Settings options allows the user to change the radius of the ring wall.
The Angles option allows the user to change the point on the circle of the ring wall where the Start and End are located.
In the Position and Orientation window, click the
Position drop-down menu to select the Origin, Radius or Start and End Angles to change. If required, use the
Lock checkboxes to fix the current co-ordinate along any axis.
The Orientation option allows the user to change orientation of the wall. The settings are mirrored by the axes shown in the graphical display. Only the Y and Z axes can be changed.
Click Apply to make the changes or click
Dismiss to discard any inputs and close the
Modify Wall (Ring) window.
