Structural Design User Guide
Modify Walls and Floors : Justification
Make the wall to be modified the CE and select Modify > Wall > Justification from the main menu toolbar to display the Wall Justification window.
To select the justification manually from the graphical display click Justification, the user is prompted to ‘Identify Pline to justify to.’, select the pline using the cursor.
Click Apply to make the changes or click Dismiss to discard any inputs and close the Wall Justification window.
The modification procedure for the wall Member Line and Joint Line is the same.
