How the origin plane of the Joint is set with reference to the Owning Section (via the POSL attribute), while its position within the constraints of that plane is set with reference to the
Attached Section (by aligning the plines defined by the JLINs of both Joint and Section). That is, with reference to the orientation of the diagram, to move the Joint horizontally change its POSL and vertically change its JLIN. Both the Section and the Joint can be rotated independently by changing their BANGs (the Section rotates about its NA, the Joint about its OPDI).
From the SECTIONS tab, in the
Modify group, click
Fitting. The user is prompted to A
Joint Specification window is displayed for the joint to which the picked section end is attached.
Click Properties. A subsidiary
Modify Properties window is displayed which allows the user to specify some local dimensional data for the selected type of joint.
For this joint set Thickness of Plt,
Dist from TOS, and
Dist from BOS. Click
OK to close the
Modify Properties window and
Apply the
Joint Specification window to complete the setting of the joint specification. (The geometry of most types of joint can be modified via appropriate entries in a window such as this. How the catalogue has been set up can affect this.)
On the Representation tab, select the
Holes Drawn checkbox. Click
OK to apply the setting and close the window.
The displayed Position Line window shows the current setting as either BOS or TOS (depending at which end of the beam the joint is situated). Change this to the opposite setting (that is TOS or BOS), select the
Re-trim attached section checkbox, and click
Apply. The joint and its attached section end move thus:
Reposition the joint correctly, then click Cancel to discard any information and close the
Position Line and
Joint Specification windows.
The user is prompted to ‘Identify end of section to be copied like’, pick the same section end as picked previously. When prompted to
‘Identify section end to be modified’, pick the other end of the same beam. Press
Escape for both of the next prompts.
