Structural Design User Guide
Modify Sections : Drag
The user can drag a section along with any attached sections lengths and secondary nodes. The section length is automatically adjusted and secondary nodes are realigned.From the SECTIONS tab, in the Modify group, click Section, select Drag from the drop-down list to display the Drag Explicitly window.
The Datum drop-down list enables the user to select the element Origin or an ID Design point as the point for the dragging operation. However, the Origin co-ordinates with respect to the World are displayed by default.
The Positioning Control window may be used to determine the new position by graphical pick, as previously mentioned.
