When set On the user must select Create or Modify to implement each creation or modification, dependant on which mode is current. When set Off, each creation or modification is implemented immediately.
When set On, the user must confirm each deletion in order to complete the command. When set Off, deletions are implemented immediately.
When set On, each edge is tagged with the number of the vertex at its start.
When set On this option allows groups of vertices to be oriented automatically when they are positioned relative, to say one edge, and are then moved to a different edge.
Allows the user to pick an edge to be modified. The adjacent Edge gadget shows the current edge number (for example: the number of the vertex at its start).
Allows the user to pick a vertex to be modified. The adjacent Vertex gadget shows the current vertex number.
Expand group - moves each edge outwards to expand the group area, by the distance specified in the adjacent Expand/Contract textbox, normal to its own direction.
Contract group - moves each edge inwards to contract the group area by the distance specified in the adjacent Expand/Contract textbox, normal to its own direction.
Expand/Contract applies to all edges in the Group and includes those on panel protrusions, and so on, therefore, excessive expansion or contraction may lead to invalid loop geometry.
Manipulates a fillet arc at the current loop vertex. When selected the Modify Arc window is displayed and the Loop Vertex Editor window becomes temporarily inactive.
