Structural Design
Create Walls
: User Defined Wall
User Defined Wall
A user-defined wall (GWALL, a soft type element of a Panel (PANE), used to represent a cross-section (usually horizontal) which is extruded (usually vertically) to represent, for example a structural column.
On the
WALLS AND FLOORS
tab, in the
Create
group, click
Walls,
select
User Defined Wall
from the drop-down list to display the
User Defined Wall
window.
The user can now create a set of panel vertices in a number of ways, specific the other attributes necessary to relate these vertices to a 3D panel representation.
Floors, Screeds and User Defined Walls (GWALL) are soft types of Panel, and are created from the same window. In the latter case, the thickness of the panel is equivalent to the height of the user-defined wall.
Refer to
Create Panels
for more information on the functionality of this window.
