Structural Design User Guide
Create Walls : Ring Wall
On the WALLS AND FLOORS tab, in the Create group, click Walls, select Curved Wall from the drop-down list to display the Ring window.
The Circle Definition pane of the Ring Wall window, defines whether the wall is a full circle or a semi circle.
If required the user can create a ring wall explicitly. To do this, from the Creation Methods pane of the Ring Wall window, select Define Explicitly. A Confirm window is displayed:
Click OK to replace the Define Ring Section, the Create Section (Ring) window is displayed.
Or click No to close the Confirm window.
The user must set the radius of the new section ring, by default the radius is 1000.00mm. From the Settings pane of the Create Section (Ring) window, input the required radius for the wall in the Radius field.
From the Angles pane of the Create Section (Ring) window, set the Angles for the start and finish positions of the segment of wall (between 0 and 360). By default, the start angle is 0 and the end angle is 180. Then click Anti-clockwise or Clockwise.
From the Position and Orientation panes of the Create Section (Ring) window:
Click Apply to create the ring wall, the wall is displayed in the 3D view and in the model explorer.
Or click Dismiss to discard information and close the Create Section (Ring) window.
