To create a straight wall, on the Walls and Floors tab, in the
Create group, click
Walls, select
Straight Wall from the drop-down list to display the
Straight Wall window.
The Positioning Control window is also displayed, the positioning functionality available for selection is common throughout all design disciplines, refer to Common Functionality Guide for further information. The user is prompted to ‘
Define Straight wall start (Snap) Snap:’
From the Straight Wall window there are three options by which walls are created available to the user:
Enter the required East,
North and
Up co-ordinates and the Start position is shown in the graphical view. The default
wrt World defines the co-ordinate system by which the position is specified.
Click OK to confirm the entered co-ordinates and activates all the functionality available from the
Create Option display. The user is also prompted to
Define straight wall end (Snap) Snap:.
Or click Cancel to discard any inputs and close the
Define straight wall start window.
Click Define Start/End Explicitly to display the
Define Straight Wall End window which is used in exactly the same way as the
Define Straight Wall Start window.
Click OK to confirm the entered co-ordinates or click
Define straight wall end window.
Click Perpendicular from to create a wall perpendicular to the wall specified for the new wall start. The user is prompted to
‘Pick straight Section/Wall to derive perpendicular from:’.
Click Perpendicular to create a wall perpendicular to a selected wall. The user is prompted to
‘Pick straight Section/Wall to derive perpendicular end to:’.
If the Confirm check box in the
Verification window is selected a line is drawn in the graphical view to show the position of the wall. Click
Accept to draw the new wall or
Reject to start again.
