DRAW User Guide
Create and Modify Views : Create Regions
To create a region, on the Home tab, in the View group, click Region.
The user is prompted to Specify the first corner or <Centre>
Input values in the dimension fields and press Enter or click to identify the first corner of the region.
The user is then prompted to Specify the opposite corner
Input values in the dimension fields and press Enter or click to identify the opposite corner of the region.
Throughout the region creation process the user can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Centre to create a region with a specified centre point. Refer to Create Region with Specified Centre Point for further information.
To create a region with a specified centre point, on the Home tab, in the View group, click Region.
Input C at the prompt and press Enter.
The user is then prompted to Specify the centre point
Input values in the dimension fields and press Enter or click to identify the centre point of the region.
Input a dimensional value in the field and press Enter or move the cursor left or right to define the width of the region. Click to confirm the required width.
Input a dimensional value in the field and press Enter or move the cursor the cursor up or down to define the height of the region. Click to confirm the required height.
