To create one of these elements, on the Home tab, in the
Project group, click
New, select
Drawing Type from the drop-down list to display the available Drawing Types and Templates.
Alternatively, on the Project tab, select
New to display the available Drawing Types and Templates.
If Backing Sheet or Overlay Sheet is selected, the user must select a Template Type from the drop-down list to filter the available Templates.
The Create windows are very similar to the
Hierarchy Browser window. Refer to
Create Drawing Sheet from Hierarchy Browser or Open Window for further information.
Either input a name in the Name field, or leave it blank if the element is to be assigned a default name.
Click Create to create the new element. A new element is created and opened.
Use the DRAW drawing and annotation facilities (refer to Add and Modify Drawing Objects and
Add Annotation for further information) to create, for example, the required symbol or backing sheet borders.
