On the Tools tab, in the
Explorers group, click
Department, select
Create from the drop-down list to display the
Create DEPT window.
The Create DEPT window displays a default name for the element followed by the next available number, for example,
DEPT2. Input a different name if required.
Click OK to apply the DEPT name or
Cancel to discard any changes and close the
Create DEPT window. By default, the
Department Information window displays.
Select the Create Registry check box to create a REGI element below the DEPT element, by default. Refer to
Create Registry for further information.
Click Attributes to display the
Department Attributes window, which allows the user to define the default attributes for the department. Refer to
Modify Department Attributes for further information.
Click OK to create the DEPT element or
Department Information window.
Registry, select
Create REGI window.
The Create REGI window displays a default name for the element followed by the next available number, for example,
REGI3. Input a different name if required.
Click OK to apply the REGI name or
Create REGI window. By default, the
Registry Information window displays.
Select the Create Drawing check box to create a DRWG element below the REGI element, by default. Refer to
Create Drawing for further information.
Registry Attributes window, which allows the user to define the default attributes for the registry. Refer to
Modify Registry Attributes for further information.
Click OK to create the REGI element or
Registry Information window.
Drawing, select
Create Explicitly from the drop-down list to display the
Create DRWG window.
DR4. Input a different name if required.
Click OK to apply the DRWG name or
Create DRWG window. By default, the
Drawing Definition window displays.
Drawing Attributes window, which allows the user to define the default attributes for the drawing. Refer to
Modify Drawing Attributes for further information.
Click Apply to create the DRWG element,
Reset to discard any changes or
Cancel to close the
Drawing Definition window.
