DRAW
Basic Operations
: Create and Modify Visual Styles
When labels, text, dimensions and view frames are added to a drawing they are assigned a visual style which controls their appearance. For example the colours, line weights, styles and text sizes.
DRAW is supplied with the AVEVA Default visual style which is initially assigned to labels, text, dimensions and view frames by default. However, visual styles can also be defined by users. A user-defined visual style can be set as the default style for labels, text, dimensions and/or view frames. The creation and modification of visual styles is an administrative task, refer to
Visual Styles
for further information.
The visual style assigned to objects can be changed from the default at any time, to any style, after they have been added to a drawing.
