DRAW User Guide
Options and Setup : Options : Drafting Options
On the Project tab, click Options, click Drafting to display the Drafting Options.
Select the check box to specify that holding down Shift adds or removes selected objects.
On the Drafting Options, click Advanced to display the Advanced Draft Settings window, which is used to specify the Grid Settings and Object Snap settings.
Select the Grid Settings tab to specify the current sheet/view grid display settings. The user can also define grid spacing, grid style, and ruler display settings.
Input dimensional values in the X and Y fields to define the grid spacing.
Select the Object Snap tab to specify current sheet/view object snap settings. The View and Sheet/Region tabs are identical.
Select the Object Snap On (F3) check box to turn on snap object functionality.
Select the Object Snap Projection On (F4) check box to turn on snap object projection functionality.
Select the check boxes on the View and Sheet/Region tabs to specify the types of snap points that are available (refer to Snap Object for more information).
Click Select all to select all available snap points.
Click Clear all to de-select all available snap points.
Click OK to apply the grid and snap settings or Cancel to discard any changes and close the Advanced Draft Settings window. The user is returned to the Drafting Options.
Select the Animate dynamic hints check box to display hints with full opacity only when the user is not active (for example, the user is not moving the mouse).
De-select the Animate dynamic hints check box to display hints at all times, regardless of the user activity.
Select the Anti-aliasing check box to turn on anti-aliasing.
