DRAW
User Interface
: Quick Access Toolbar
Options on the Project tab can be added to the Quick Access Toolbar for quick and convenient access.
By default, the Quick Access Toolbar includes the following options.
Save Work
Click to save any changes made to data using the DRAW module. The facility is also available on the
Project Tab
Get Work
Click to discard any changes made to the drawing data since the last Save Work was executed by any user. The facility is also available on the
Project Tab
Undo
Click to Undo the last change made to a drawing. The user can continue to undo previous modifications.
Redo
Click to reverse the last undo made to a drawing. The user can continue to redo undone modifications.
To add a tab option to the Quick Access Toolbar, right-click the required option and select
Add to Quick Access Toolbar
from the drop-down list.
The tab option displays on the Quick Access Toolbar.
By default, the Quick Access Toolbar is positioned above the tabs. To position the Quick Access Toolbar below the tabs, right-click a tab and select
Show Quick Access Toolbar Below the Ribbon
Alternatively, on the Quick Access Toolbar, click
and select
Show Below the Ribbon
When the Quick Access Toolbar is positioned below the ribbon, the drop-down list options become
Show Quick Access Toolbar Above the Ribbon
and
Show Above the Ribbon
Customize Quick Access Toolbar
includes options for item removal and can also be returned to the default settings.
