DRAW
User Interface
Tabs
: Auto
Auto
Create Group
General
Click to display a drop-down list with the following options:
Drawing
Allows the user to create a general ADP drawing. Refer to
Create General ADP Drawings
for further information.
Sheet
Allows the user to create a general ADP sheet. Refer to
Create General ADP Sheets
View
Allows the user to create a general ADP view. Refer to
Create General ADP Views
Pipe Sketches
Allows the user to create a new pipe sketch. Refer to
Create Pipe Sketches
HVAC Sketches
Allows the user to create a new HVAC sketch. Refer to
Create HVAC Sketches
Isometric Drawings
Isometric ADP defaults are defined by the administrator.
Refer to
Defaults
Modify Group
General
Drawing
Allows the user to modify a general ADP drawing. Refer to
Modify General ADP Drawings
for further details.
Sheet
Allows the user to modify a general ADP sheet. Refer to
Modify General ADP Sheets
View
Allows the user to modify a general ADP view. Refer to
Modify General ADP View
Equipment Centres Group
Equipment Centres
Allows the user to define the setup of equipment centrelines on a general ADP view. Refer to
Equipment Centrelines
Tools Group
Drawing Search
Allows the user to search for Isometric ADP drawings. Refer to
Search for Isometric ADP Drawings
Standards
Allows the user to add HVAC standard drawings to the Isometric ADP drawings. Refer to
ISOADP Standards
Isometric Direction
Allows the user to modify the view direction of an Isometric ADP drawing. Refer to
Look Direction
Nudge Up
Allows the user to increase the view scale of the Isometric ADP drawing. Refer to
Nudge the View Scale
Nudge Down
Allows the user to decrease the view scale of the Isometric ADP drawing. Refer to
Nudge Factor
Allows the user to define the scale used to nudge the view scale. Refer to
Dimension Cycle
Allows the user to define the display style of dimensions on the Isometric ADP drawing. Refer to
Dimension Style
Log
Allows the user to view the log file for the generated Isometric ADP drawing. Refer to
Log File
Revision
Allows the user to define the revision status of the Isometric ADP drawing. Refer to
Revision Details
Visibility
Allows the user to specify the visible layers for the Isometric ADP drawing. Refer to
Layer Visibility
Defaults Group
General
The default files used for General ADP production are defined by the administrator.
Refer to
Set ADP Defaults
Isometric
The default files used for Isometric ADP production are defined by the administrator.
Refer to
Defaults
