DRAW
Isometric Automatic Drawing Production
Drawing Content
: Isometric Detail
Isometric Detail
The drawing contains a single graphical view of the Fabrication Spool, which includes a variety of annotations and can, if required, display the following internal details:
Design components are tagged to match the entries in the Material Parts Table.
The centreline is dimensioned with either a full or overall dimension type dependant on the default choice, this can be modified by the user. Refer to
Modify Drawings
for further information.
Labels are provided to indicate continuation to other sheets in this drawing or to other parts of the 3D model system (as long as the connection data is available).
Certain elements such as Tees, Bends and Elbows are labelled to indicate their coordinate position, while BRCO elements are labelled to provide connection data.
The start position of the Spool is marked as the origin, this relates to the nearest grid-line and displays on the Isometric ADP Keyplan.
