The Simple Report window allows the user to quickly generate reports, however the report template cannot be saved.
Click Run to generate the report. Click
Cancel to close the window.
If the Screen check box is checked, the report displays on screen. For example:
If the Screen check box is not checked, the report is generated as a text file with the specified filename in the specified folder.
