Click Open to export the selected sheets.
A standard Browse for Folder window then displays. The user must specify the folder into which the files are to be exported, then click OK to proceed with the export.
Select Export to SVG/AVEVA.NET from the drop-down list to define a .SVG file or an AVEVA.NET file as the export format.
Click to define the settings for the export. Refer to SVG/AVEVA NET Export Settings for further information.
Select the check box to create a log file (.txt file) when the export is processed. The Log File field becomes active.
Alternatively, select RGB values from the drop-down lists to define a custom background colour for the export file.
Alternatively, click Pick Colour to display the Color window. The functionality of the Color window is explained as part of the process to modify the DRAW Display Options. Refer to Colours for further information.
