To select the revision to compare from, on the Manage tab, in the
Revision group, click
From, select a revision state from the drop-down list.
To select the revision to compare to, on the Manage tab, in the
To, select a revision state from the drop-down list.
The comparison then takes place. Objects that have been added since the From revision display in green. Objects that have been deleted display in red. In the case of objects that have been changed, the object as it was in the
From revision display in red, and the object as it is in the
To revision, or as it is now, displays in green.
In the example, the triangle is in the From revision, but is not in the current drawing (or in the
To revision). The red rectangle indicates the display of the rectangle in the
From revision, and the green rectangle indicates the display of the rectangle in the current drawing (or in the
To revision). The green circle indicates that it has been added since the
From revision and is in the current drawing (or in the
To revision).
Throughout the compare revision process the user can press ESC to cancel the command. Additional functionality is also available.
