DRAW User Guide
Data Management Facilities : Create and Compare Drawing Revisions : Create and Modify Revisions
To create or modify a drawing revision, on the Manage tab, in the Revision group, click Editor to display the Revision Control window.
The Revision Control window lists all of the existing revisions for the drawing sheet.
Click + to display the row, if it is not visible.
Click - to suppress the row display, if it is visible.
The Column Filter allows the user to add or remove columns in the Revision Control list. Select the required check box to add a column to the Revision Control list. Clear the required check box to remove a column from the Revision Control list.
Click Apply to save the revision modifications.
Click OK to save the revision modifications and close the Revision Control window or Cancel to discard any changes and close the Revision Control window.
