Press the down arrow key and select Glyph to select a different symbol for the marker point. Refer to Add Marker Point with Specified Glyph for further information.
Press the down arrow key and select Insert to add the marker point to the drawing.
Press the down arrow key and select Size to specify the size of the marker point. Refer to Add Marker Point with Specified Size for further information.
Press the down arrow key and select Undo to undo the last action.
