To add an image to a drawing, on the Annotate group, in the
Insert tab, click
Image to display the
Open window. The user can browse for and select the required image, click
Open.
Input values in the dimension fields and press Enter or click to identify the location for the centre of the image.
Input a value in the field and press Enter to define the scale factor. Alternatively the user can move the cursor away from the insertion point to increase the size of the image or move the cursor closer to the insertion point to decrease the size of the image. Click to define the scale factor.
Input an angular value in the field and press Enter to define the rotation angle. Alternatively, the user can move the cursor around the centre of the image to visually select the required angle. A ghosted preview of the image rotates to reflect the angle. Click to define the rotation angle.
