Press the down arrow key and select Angle mode to specify the pitch circle dimension angle mode.
The user is prompted to Specify angle mode <Free>
Press the down arrow key and select Design item to specify a design item to annotate.
The user is prompted to Select design object.
Press the down arrow key and select Mode to specify the pitch circle dimension mode.
The user is prompted to Specify dim mode <Diameter>
Press the down arrow key and select Style to specify the pitch circle dimension style.
The user is prompted to Specify dim style <dim line>
