Press the down arrow key and select Direction to specify the direction of the dimension.
The user is prompted to Select option <Left>
The option is only available for Combined Left, Combined Right, Baseline Left, and Baseline Right linear dimension types.
Press the down arrow key and select Orientation to specify the orientation of the linear dimension.
The user is prompted to Select option <Orthogonal>
Alternatively, input O at the prompt and press Enter to specify the dimension orientation as orthogonal.
Press the down arrow key and select Type to specify the type of linear dimension.
Press the down arrow key and select Undo to undo the last action.
