Software Customisation
PML 1 Expressions
Positions, Directions and Orientations in Expressions (AVEVA E3D™ only)
: FROM
FROM
In some cases we require an offset from a fixed point, other than the position of an item. For example, a point or attribute.
The FROM syntax is used for this. We may still use WRT in combination with FROM, but in this case the WRT is only used to determine the axis direction and not the offset, since the offset is specified by the FROM part.
Consider the following:
Item
Comments
A SITE at (0,0,0)
With default (World) orientation
A ZONE at (100,0,0)
An EQUIPMENT at (100,0,0)
With orientation ’N IS E
A BOX at (-100,0,0)
Figure A:2.
The Effect of FROM
The result of
Q (N 100 WRT /* FROM /BOX1),
shown as
in , will depend on the current element.
Location
Result
World, Site, and Zone
(200,200,0) since the offset of N100 is applied in world axis rather than /BOX1 axis.
Equipment
(100,200,0).
The default axis for the result is the Zone.
Box
(200,0,0), because the default axis for the result is the Equipment.
The result of
’Q (N 100 WRT /BOX1 FROM /* )
is different:
Location
Result
Site and Zone
(100,0,0)
Equipment
(0,0,0)
Box
(0, -100, 0), because the axis for the result is the Equipment.
The result of
’Q (N 100 FROM /* )’
is different yet again.
For this we cannot mark an absolute point on the diagram since the default WRT will vary with the current element. In fact for the SITE, ZONE, EQUI the point
is marked in , and for the BOX the point coincides with the ZONE.
Figure A:3.
Varying WRT
Location
Result
Site and Zone
(0,100,0)
Equipment
(-100,100,0), because the default result axis is the Zone.
Box
