Software Customisation
Object Type Details
: VIEW Gadget: VOLUME Views
Members
Name
Type
Purpose
Background
REAL Get/Set
Get or set Background Colour Number
Background
STRING Set Only
Set Background Colour Name.
Contents
REAL ARRAY[2] Get/Set
Get or set User Contents ID.
Defcall
STRING Get/Set
Get or set default interaction callback.
Height
REAL Get Only
Get View Height.
Highlight
REAL Get/Set
Get or set Highlight Colour Number.
Highlight
STRING Set Only
Set Highlight Colour Name.
Prompt
GADGET Get/Set
Get or Set User Prompt paragraph gadget.
Subtype
STRING Get Only
Get Subtype of graphic view.
Width
REAL Get Only
Get View Width.
StatusLine
BOOLEAN Get/Set
Get or set Status Line ON (TRUE) or OFF (FALSE).
Borders
BOOLEAN Get/Set
Get or set Borders ON (TRUE) or OFF (FALSE).
Direction
REAL ARRAY[3] Get/Set
Direction vector [dE,dN,dU].
EyeMode
BOOLEAN Get/Set
TRUE for Eyemode FALSE for Modelmode.
Limits
REAL ARRAY[6] Get/Set
Limits box [E1,E2,N1,N2,U1,U2].
Mousemode
STRING Get/Set
'ZOOM', 'PAN', 'ROTATE', WALK'.
Projection
STRING Get/Set
‘PERSPECTIVE’ or ‘PARALLEL’.
Radius
REAL Get/Set
View Radius distance >0.
Range
REAL Get/Set
Range distance >0.
Refresh
NO RESULT
Refreshes the display of the gadget.
RestoreView
REAL Get/Set
Restores view saved as given view number.
SaveView
REAL Get/Set
Saves view as given view number, in the range 1 to 4.
Shaded
BOOLEAN Get/Set
TRUE for shaded FALSE for wireline.
Step
REAL Get/Set
Step size >0.
Through
Through point [E,N,U].
WalkThrough
BOOLEAN Get/Set
TRUE for Walkthrough (equivalent to Eyemode).
LabelStyle
STRING Get/Set
Set by specifying ‘ENU’ or ‘XYZ’. Default is ‘ENU’.
Bearing
REAL Get/Set
View bearing
-180 <= bearing <=180
Elevation
REAL Get/Set
View elevation
-180 <= elevation <=180
Table 2: 139.
VIEW VOLUME Members
Methods
Name
Result
Purpose
Background()
STRING
Returns the BACKGROUND colour as a name string.
Highlight()
STRING
Returns the HIGHLIGHT colour as a name string.
SetSize(REAL width, REAL height)
NO RESULT
Set view size.
RestoreView(REAL storeNumber)
NO RESULT
SaveView(REAL storeNumber)
NO RESULT
Saves view as given view number.
Table 2: 140.
VOLUME VIEW Object Methods
Command
The VIEW ... VOLUME command puts you into View Setup mode. You remain in View Setup mode until you use the EXIT command.
(VOLume)--+-- STAUTUSLINE --+-- ON --.
| ‘-- OFF -‘--------------.
+-- BORDERS --+-- ON --. |
| ‘-- OFF -‘------------------|
+-- SHADING --+-- ON --. |
+-- <cursor> -----------------------------|
+-- LOok --+-- <dir> ---------------------.
| |-- THRough---. |
| |-- FROM -----| |
| ‘-- TOWards --+-- <pos> ----. |
| |-- <gid> ----| |
| ‘-- ID @ NL ‑-‘--|
+-- ISOmetric --+--
value
+-- PLAN ---------------------------------|
+-- ELEVation -- (one of N/S/E/W/X/Y) ----|
+-- CLIPping -----+-- ON --. |
| ‘-- OFF ‑‘--------------|
+-- CAPping ------+-- ON --. |
+-- PERSPective --+-- ON --. |
+-- WALKthrough --+-- ON --. |
+--RADius ---
value
+--STEP -----
value
‘--RANGE ----
value
Figure 2:73.
Syntax Graph -: Setting Up a VOLUME VIEW Object
Where:
<cursor> is the syntax for selecting the cursor type, as in 2-19
<border> allows control of zooming and panning as in 2-20
The StatusLine must be ON for Borders to be displayed.
Default:
StatusLine ON; Borders ON; Shading OFF.
View direction:PLAN or LOOK DOWN.
Limits: AUTO (set to current view limits).
